Brake Pedal Creaking?
SpecAlloys
Aug 7, 2012
11
Gentlemen,
My brake pedal has been making this "door opening" creaking noise when pressed for a couple of weeks now. Sprayed a touch of WD40 up there under the dash which didn't help at all. The noise is definitely coming from the inside.
Any ideas?
BlkMax
743
Wasilla, AK
Try something a little more robust like a little bit of lithium grease spray. WD40 is very light and will vaporize off, especially when dealing with pressure.
You might also take a close look, you may have hogged out the holes or worn the pin on the brake pedal...:confused:
Good Luck
SpecAlloys
Aug 7, 2012
11
thanks - could you explain "hogged out the holes" I want to be sure I am looking at all possibilities
duramaxsilvy
Sep 21, 2012
9
wd40 for me, i couldnt get the straw where i wanted to...so i went all out coated it all. truck smelt for a week and the squeak is gone!:woott:
