Borg Warner S400SX4
Psini
Mar 14, 2017
21
Queensland, Australia
Hi all, hoping some guru on here can give me a quick answer.
Been slowly getting parts together to eventually go compound over stock on my LBZ.
I have found a reasonably priced new
S400SX4 (P/N 171702).
It is a 1.32AR housing, not looking for huge response, just mainly for towing purposes.
This is stock bottom end, aiming for 600-650 rwhp max with the fuel upgrades to suit.
Will this turbo work for what I want.
There's so much info on S400 turbos I don't have time to research it all.
I believe the seller bought it for an LS turbo build.
Pic attached of the specs.
Thanks in advance.
Bdsankey
3,929
1,084
Neenah, Wisconsin
Yes, that is the PN for a Borg Warner cast wheel S475/96/1.32AR T6. That would work well over the stock turbo. If you wanted to try and make it react a touch quicker you can also buy the 1.15AR T6 housing if you were unhappy with its driveability/response.
Reactions: Psini
Psini
Mar 14, 2017
21
Thanks for the info Bdsankey, much appreciated 👍
