I am considering purchasing the boost tubes for my LLY. What gains can I expect and why do you only offer hot side tubes??
Michael,
I got the driver's side boost tube on. It looks great and installation was a breeze. While I was under the hood I swapped in a 3.5" V-Band compressor outlet flange to eliminate the necked down restriction coming out on my compressor. Compressor side of my turbo is breathing easier now.
Do you have any recommendations on upgrading the post intercooler tubing into the intake? I don't mind replacing the factory cast piping or air intake heater grid.
Thanks
John
Thanks
John
love those weekend projectsOooooh I bet you like your matching colored tube huh Larry
It is not going to help you unless you push at least 70 lb/minute. IOW, with stock turbo, the cold side is already relatively restriction free. Remember, after passing through the CAC, there is a huge velocity reduction with its density increase.
You have done all that is practical at this point. If one were to determine that 3" is necessary on the cold side, this would necessarily mean that your hot side would be undersized at 3", and would need to go to 3.5".
I hope I am making sense here.
If over 90 lb/minute, 3.5" would be a benefit. But it would really need a newly designed CAC as well, with 3.5" hot side connections. As you say, it also depends on efficiency (heat). The less efficient, the bigger you want.
However, pre-turbo fogging would slow air charge down enough to make 3" very feasible. 3.5" is very expensive and big, there are maybe a handful of places in the country that mandrel bend 3.5". I found one, and the prices were scary.
IMO.
why do i have a red dot next to my name?
why go 3.5 when your turbo is only 3.0
90lb/minute is gt42/s400 territory
A place that does diesel exhaust systems could make. Would the Alum. they use for exhaust be too thick?
The air is much more heated from being compressed and it expands after it exits the turbo. Just lookinbg for ideas on how to get friction flow lowered.
