You big turbo should be pushing 1/2 of the total boost. On a stock fuel truck on an all out race tune, you should see 45- 50ish psi total boost.
Let's say 50 pounds of total boost. So you say the primary (big) charger should be making 25 psi. This places the pressure ratio of the "big" charger around 4.4 and the stock charger around 2.7. That makes the total boost of the stock charger 9.25 psi to make your 50 psi of boost with the big charger making 25 psi.
This example isn't too far off on a stock set of twins. Go up in kit size and this "1/2" of total boost will not work well, IMHO.
