For some reason my box sits higher than the cab when looking at the body lines. Attached is an older picture where you can kind of see it and when I get home I will try to add a picture of it as it sits in my garage right now. It is worse now.
I don't believe the frame is bent as the top of the box is about the same distance away from the cab at the bottom. Are my cab mounts shot? I did notice a popping noise when I made sharp off camber turns into parking lots and driveways etc. Not sure if that's an indicator of a bad cab mount or not.
