Body mount part numbers
6,042
My front and rear cab mount wont tighten how can i resolve this issue? It is a crew cab.
you are pretty much f**ked. the nuts are capture nuts in the cab and when you use an impact, it can easily tear them loose. you may be able to tear the interior apart and get to the nut from the top, otherwise you will need to cut the bolt off, lift the cab and then try to weld the nut so it quits spinning.
Wturnbo
33
Flagstaff,Az
The bolts are already out i guess they ell out went put some new ones on and they just spun it would get tight by hand then put a wrench on it an it would just spin back loose kind of weird i thought and Yea thats what i was hoping not to do but if its the only way then it is what it is. used vehicles always give you one big headache with something this is going to be it.
PhilsLB7
Way Better Than Facebook
Jun 29, 2009
810
Tennessee
James thank you for bringing this up again and commenting on the poly mounts. This is the next thing I need to do to my truck and was trying to decide between the poly mounts or Dorman mounts. Looks like I’ll be going with the Dorman mounts. Appreciate Yellowchevy posting those part numbers too.
