So here is an update to my BCM saga. I got the new Body Control Module installed and programmed it with my VIN and the truck did the same thing with my dash lights staying on and the Radio not turning on when you put the ignition in the "ACC" position. So I was told I could find a VIN with the same options as mine for a different model year. I was told by Greg from CPS A/V that it would be best to find a 2009 to 2010 model year VIN with my same options. So I found one that is really close to mine and I flashed my BCM with that VIN and low and behold my trucks works perfectly. The radio comes on as it should the dash lights go on and off as they should. But now my remote start will not work as well and I have a Check Engine Light. The code that I pulled is:
Body Control Module
U1511 Symptom 00
Inter-device Dedicated Bus Lost
Communication with Device 1
This was pulled using a Tech2. Does anyone know if all the VIN numbers on all modules (ECU, BCM, TCM, etc.) need to match in order for that code to clear or what the code even means? I also need a VIN that is closest to my VIN with the same options for model year 2009 / 2010. I have verified that it is my BCM firmware that is causing all my problems with this new radio. I was wondering if we had an programming experts out there that can help me with this. Can anyone offer some help / assistance? Thank in advance.
