Block Heater Plug
03-GMC
Let there be light!!
Mar 26, 2009
485
SLC, Utah
I have my plug hanging out between the pass. side headlight and the hood right by the grill. I had to cut some of the wire loom that it was wrapped in so I could stretch it over there.
X2 mine is in the same place i found that was the easiest place to put it and still easy to get to. I hated having to pop my hood every night to plug in my truck.
9,905
151
Since I haven't got my webasto working, I pulled my cord up as far as I could and zip tied it to the battery and then tucked it down beside the battery-out of the way but easy to reach when I need it which lately hasn't been at all!!
I wish it would snow.....:(
Orangevale Diesel
Orangevale Diesel
Oct 9, 2012
Orangevale, CA
2002 6.6 block heater plug location
2002 6.6 block heater plug location- look to lower end of battery for plug in cord look on Right side (passenger- always directions are stated from sitting in driver seat) strapped to positive battery cable.
hrlyguy2
Dec 2, 2011
274
IL
My lbz is routed through between mine bumper and grill.Not in use I push it back in..No extensions.Reached perfect.
rms2012
Dec 7, 2011
155
Phoenix
Same here. You have to be creative in routing it - but it ends up on the right edge of the grill. The cap exits the next grill opening, comes around & snaps it tight. :thumb:
Harbin_22
3,858
Southern Indiana
If you take the time to get it out of the factory wire loom, you will have more then enough to put it wherever you want it. Take the passenger inner fender out and it is really easy to get to.
