LB7: Blew turbo
Feb 2, 2019
93
33
Utah
The LDS one, also the duramax tuner ones use a stock compressor cover, the LDS one has a bigger higher flowing cover to keep the correct map groove in the housing. Lots of others modify the stock cover with a insert, weld, ect and the map groove is not as good.
Have you used either the lds or dt
2003 LB7
EFI LIVE
CAT FUEL FILTER
5 inch flo~pro
Sitting on 33*12.5-44 ballistic 959/Atturos
Robby Avery
GM TECH @ FENDER GMC
Jul 31, 2008
820
Norman Park, Georgia
I cant speak for lds but where the dt ihi orginated the first 64mm was really a performer. I liked it so much that I planned on one for my lb7 then the g2 67mm came out and being that charger will support 800hp sold me I never plan to make anything over 750 so it suits me well and has a little growing room if needed:thumb:
Feb 2, 2019
93
33
Utah
Also what’s your set up on it how is the lag
2003 LB7
EFI LIVE
CAT FUEL FILTER
5 inch flo~pro
rcr1978
790
Spring Creek, NV
I'm at 6k ft with a 475 over it and 100 overs so the lag will not be comparable to a single setup. It doesn't spool quite as fast as stock but the 475 is likely holing it back hurting the spool a little.
Feb 2, 2019
93
33
Utah
I think I’ll go with that Lds 68 it’s a hire to fit drop in 360 thrust l2a cooled and will support up to 750 whp and that’s just about where I want to sit I’ll may be having to re tune to justify the bigger turbo but we shall see
2003 LB7
EFI LIVE
CAT FUEL FILTER
5 inch flo~pro
torqued2dmax
646
Brookville, PA
CAT FUEL FILTER
5 inch flo~pro
What rods do you plan on running , or are you just going to run her till she pops !
