Blew a headgasket
9,905
151
Unless you have milky oil, that's not where it's coming from. My guess is the line for the coolant you capped is leaking.
5,927
It's definitely coming from that gasket... question is why would coolant be leaking into the valve cover? :D
you should be leaking oil there then too or like Dale said, have milky oil. i bet its traveling down from somewhere above there along the edge of the head from engine valley.
paint94979
Beer Nazi
Sep 18, 2006
11,715
That valve cover has leaked oil since day 1 it's just closer to the front of the engine
5,927
But you should be seeing something from where the water is coming from as well. either way, the oil should be milky if thats the case
paint94979
Beer Nazi
Sep 18, 2006
11,715
Oil doesn't appear to be milky but coolant is definitely coming from the vavle cover
