Pump it slow and fast
At the same time?
Tried slow, tried as fast as I can. Tried half strokes. No luck... Leaning tword getting a new master
I've tried searching for this but haven't really found any good concrete answer... other than just pump the pedal.
I have my tranny out of the truck, so I can do whatever is needed to get this bled completely and properly.
What is the correct way to bleed the clutch hydraulic system?
Did u replace the slave cylinder?
I took a cap from a can of PVC glue, cut the stick off, drilled a hole in it, attached a bolt and nut type valve stem, and put that on top of the clutch master cylinder reservoir, the turned my regulator on my compressor down to 25psi iirc, but I'd start lower to be safe just in case my memory is failing me, and pressurized it with a clamp on air chuck and opened and closed the bleeder valve until nothing but fluid came out.
not this exactly but but ive got about 4k worth of their junk shit. I had the adjustment nuts on my sintered iron clutch back off and cause a bunch of issues. and I have one of their ceramic clutches rated for 650hp smoked, sitting in my garage. truck is nowhere near 650hp
Why didn't you go southbend?
Not what I wanted to hear. I've put about 10 of their clutches in trucks recently with no problems.
We will see how this one holds up. I havnt had time to call them and see what the deal was..
in dodges? ive heard really good things about their dodge clutches which is why I went with them. I will say that the ceramic clutch gave up the ghost at the 175 mark the first time I hooked it with that clutch. for some reason the pedal never came all the way off the floor and I didn't notice until right before it went. the sintered iron was an easy fix but shouldn't have happened. my experience with their customer service has not been good. every time I call them (usually for advice because they really wont warranty anything) no matter what the issue is, they tell me its a misapplication and I should be using another clutch. aside from the fact that the sintered iron had adjustment issues it has held up really well to very many hooks.
