LLY: bleeding injectors
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Make sure you get fuel out of the bleeder screw on top of the filter housing, then if there are no other leaks or issues you should be able to crank until it fires up! It's usually under 30seconds
ncdmax03
125
ok the filter is off i got an lift pump and i just put a cp3 on it and it still wont fire off iam still getting air on the pass side injectors
Harbin_22
3,858
7
Southern Indiana
You should bot be cracking the injector lines open. Not like old school systems. It will start if everythibg is in correct working condition. Why did you change cp3's?
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
Do you have anything to monitor rail pressure? How long have you been cranking? What kind of lift pump? Did you delete the factory filter?
ncdmax03
125
the fpr went out i changed it and it still wont fire yea i checked it with efi tryin bout a week to crank it now. airdog 165 and the filter is deleted the rail psi is around 200 to 400 while wanting 6000 to 10000 and iam lost dont know what to do
Dragonsfireloki
Nov 6, 2011
175
37
North Dakota
FPRV is going to be on your driver side, PPE has directions on installing their race fuel valve and that is pretty detailed. Here is the link for it.
http://www.pacificp.com/pdf/45-10 Race Valve V6.pdf
If it is your FPRV, i don't believe that efi will tell you from what i understand of efi all it can tell you that would be related would be rail pressure and commanded rail pressure. Search "bottle test" and that will explain on how to check the FPRV.
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
Never crack a injector line open on a common rail diesel to bleed air out of the system. Its very dangerous do to high fuel pressures. Not like the old days.
ncdmax03
125
It was lopein real bad in gear an I was in the middle of a pull and truck shut down and hasn't cranked back yet
ncdmax03
125
