Help: Bleeding brakes
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Tried to bleed brakes again tonight. Took the master cylinder off, it was fully bled already...did the pump method again all 4 corners and master cylimder fittings and still no change. I did notice however on the driver side caliper it sounded like sucking air during pedal return...checked feed line, replaced washers, still no change. Could a caliper leak air by and not visibly have any defect??
Porno Joe
513
South of Pittsburgh
Yes a caliper can be leaking from the o ring around the piston. Never had it happen on a car or truck, but on my harley the caliper was leaking around the piston, I had no visible sign it was leaking until i let the bike sit for a few days and saw the drips under it
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Evan realized and corrected teh problem....I didnt even notice I had swapped the rear calipers when i had them off to clean and paint them last year....bleeders were on the bottom. now i have stock-like pedal feel again! :hug:
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
Glad you figured it out. When I put disk brakes on my 1980, I had a issue bleeding them as well (pedal was spongy no matter how much fluid I put through). The bleeders were "near" the top, but not the very top sitting in the caliper mount. Once I removed them from the caliper bracket and bled them with the bleeder at 12 o-clock, they worked mint.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Good thing you figured it out because no one would have thought of that.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
It's a easy thing to do when you have them both off at the same time.
DPC
323
Adams, TN
I have been trying to get my brakes bled for 3 days and had no idea what was wrong until now. I had my axle out of the truck for a locker and bigger axle shafts, never paid attention to the calipers when I put them back on. My bleeders are on the bottom...
