Billet S468 real world numbers
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
So everyone knows my truck made. 918/1629 on the dyno but I still use this thing everyday from daily driving to pulling a trailer every now and again. First tank of fuel netted 20.4 mpg on tune 3 with both city and highway driving. Today I went to Dayton Ohio with a bumper pull trailer with a rolling 1/2 ton chassis on it and went 289 miles on 16.4 gals of fuel netting 17.6 mpg. Here is a pic of the EGTs cruising between 75-80 mph.
All around great charger that can do double duty if you use some common sense!!!!
06dmax
Aug 5, 2009
295
what do you run for boost at wot? i wish my truck put out hp numbers like yours i got built motor very similar to yours just i have a 475 and 45 over injectors and my truck is barley breakin 600 and 13.s down the track do you have any pics of your turbo and intake set up? i think my intake set up and maf tuning has a big part in why it aint running right. im also only seeing around a peak of 42psi of boost
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
at 6500 lbs, your dyno HP puts you in the 130 trap speeds..
I would venture to guess your real world dyno numbers are a max of 800.
Great turbo none the less, I really want one.
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
45ish lbs of boost, I've seen a peak of 50. I really didn't watch the gauges at the track , I was scared of it. Lol
brandon06dmax
the reckoning
Apr 29, 2013
365
jactionville nc
I don't have a built motor but I have a s475 and im seeing 55 maybe a hair more I have 60% overs and a stock lbz cp3 I don't know why your boost is so low I c 40psi on my smallest tune
06dmax
Aug 5, 2009
295
You also have a Bat, every charger reacts different.....
I have a billet compressor wheel in mine deffinately made a difference but not as much as I was hoping for haha
And thanks for the intake pic that's how I should have done mine but I messed up and left my welded 3 inch comin out the front in make my intake situation a pain! Finally got a cobra head elbow and gonna try to get a more free flowing intake on there and get the maf tuning then hopefully I'll see so better performance out of it
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
A dyno is definitely used as a tool, but I have a few disadvantages working against me. I have a straight axle and I'm lifted up, regardless it's moving for a big truck and I left soft at the track, I honestly believe if I lost a little curb weight and put slicks on it would be in the 10s no problem.....I plan on 4 linking the front and getting it back down on the ground and possibly doing a cage this winter if everything goes as planned!!! TS has a 10.5 index class that I'm shooting for! Stay tuned for updates.:woott:
