Biggest streetable Injectors
S Phinney
4,008
Quncy, Fl
With a lb7 make sure you do the Motorsports nozzles at 65 over version and don't go more than 30% oversized. That will be around 100 overs and the life span will be greater.
The Kansan
Aug 30, 2013
179
Topeka, KS
Might be a dumb question but are these the SAC nozzles you are talking about? I dont quite understand what you mean by 65 over and 30% oversized. Does this mean that you use a 65% nozzle and then increase flow with the injector itself 30%?
S Phinney
4,008
Quncy, Fl
Yes they are sac nozzles. On a lb7 you have a choice if a 45 or 65 over that is stock untouched. It just flows that much more than a oem stock voc nozzle. Then you extrude it another 30 percent. The final over stock size would be about 100 percent.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Streetable can be a loose term. Some guys streetable is way differant then others.
Exactly. I would never put 100s in a street truck. My 45s will black out the road if I hammer it while under the charger. They stink pretty bad in cold weather too. 100s are even worse.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
You also swear by fixed vane chargers. My 72R/483 combo with 100 overs doesn't even haze on my small tune. Wide open from a dead stop it is clean as stock.
5,813
Smoke, haze, throttle control can all be address via the tune. If smoke is an issue, it's either a hard part issue or the tune. It takes time to dial a big injector truck in and keep it clean while still making it spool up fast.
