Info: bigger injectors: what are they like @ idle?
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
My 40% Dipper injectors dont smoke at idle when warm, but they definitely do smell more than a stock truck. As the truck warms up, it gets better, the smell really isnt bad, but you definitely do notice it.
just as quiet as stock injectors, starts fine in sub-zero temps. I have a stock LBZ long block in my truck, so 16.8:1 compression ratio vs stock 04-05 LLY at 17.5:1.
Also, if its below 50* or so at cold start, they do haze blue-ish and the smell is pretty strong and makes your eyes water if you are standing around the back of the truck before its warmed up.
Whats weird though is my buddy's fully-built LLY with 125% over injectors doesnt smell any worse than my 40%. His 125% sticks have zero smoke at idle, but obviously when driving at part throttle/lower boost, they are somewhat smokey.
A little off topic here but why did they lower the compression on the lbz's? That should make life easier on the pistons i would think?
3,732
300
I would have to say that injector rated-size is not constant, therefore your 60 overs may be the same as someone else's 40 overs...just an example: exergy>extrude honed
That's true, and that's why I said who did them. Take it for what its worth: my personal experience on my particular truck. Though this is probably not making the OP's decision any easier, lol.
Sent from my Galaxy Nexus using Tapatalk 2
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
Not to start a pissing match... But my experience has been Exergy as the most consistent on injectors... You can bet on if they say 60% injectors, they will be all balanced and flowed to the specific MM3... Just throwing it out there... I highly recommend them.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Well I would hope so, those flow sheets cost some dough:D
Matt Woertz has a great source too down in KY. I'm going to be doing a lot more business with them in the future:thumb:
