Bigger hold down bolts
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,477
463
Central OH
All you guys have been doing it wrong, guy on bookface "upgraded" to bigger injector hold down bolts :spit:
3,724
292
As someone who owns a LB7, I feel I am missing something. Does the bolt normally go through the rocker cover into the head? And if not, why would this not work (if there was sufficient metal around the stock boss)?
Edit: learned how to use Google, and it does look like the bolt is supposed to go into the head. So yeah, that's a bad idea...
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,477
463
Central OH
Correct, the rocker housing normally isn't threaded
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Jeeez he's gonna have a hell of a noise on start up lol
schulte
Jul 31, 2010
449
CT
Why not just put studs there instead?
Studs are plenty strong, especially if you get them 90mm long and run them in to a few mm shy of bottoming out. Next weakest is the hold downs themselves, but once you make them billet I don't see why you'd need bigger bolts?
Or, has someone stretched studs with billet hold downs that I haven't heard of?
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I think you missed the point of this post..
The op was poking fun at someone tapping into the lower valve cover. Which does not work
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,477
463
Central OH
AFAIK nobody has stretched a stud. And the kid that was doing this "mod" has a stock motor with twins, and reused the stock hold downs. I just think he has an extra chromosome.
