Then you will be ready for lower gears 33" tires and 4th gear Thats when things start to get interesting:coolspot:
Are the customers on this forum?...Maybe Bullfrog could shoot a PM...
I agree with you on the A/R thing. Borg stuff seems to be about .1 losser than Garrett stuff of the same number. The S475 and GT42 are very simalar. I actually had a buddy test them the same day on dyno with his tractor engine. The S400 was a little quicker lighing and was good for about 50hp less then the GT42. Drive pressure ratios have alot to do with RPM. I can make 60 psi of boost at 3000rpm withjust over 60psi of drive but at 4000rpm my drive jumps way up. A looser housing did not fix it. Simply the flow of the turbine wheel is over come. The S400 83mm turbine flow just sligthly less then the GT42 turbine.I have an S475 with an 83mm turbine and a .9 housing. Everyone I've talked to that has experience with Garretts thinks that a .9 housing is WAY too tight. But you can't compare a GT42's AR to a 3" S400, they are two different animals. Anyway, mine stays at 1:1 up to 60 PSI then the drive pressure continues up to 80PSI while boost settles at 62PSI. Response and spool up on the street is awesome, I wouldn't hesitate to tow heavy with it - at 2000 RPM I can make the boost gauge bounce with my right foot. I looked at the gauges as I crossed the 300' mark at OBX and I was at 62 PSI boost and 80 PSI drive. For sled pulling the tight housing is awesome. Drag racing the bigger housing would give me more power in the higher RPM and I'm going to test a 1.0 housing on it at both pulling and the track to see which I want to go with permanently. If I still want more flow I'll step up to an 87mm wheel in a .9 housing and may step up to an S480 at the same time.
Now all that said everybodies drive pressures will be different. Cams, heads, and tuning can make a difference in drive pressure.
Why not run a divided housing with a flapper valve to block one section of the turbine till it gets wound up. Then when you hit a given rpm/boost/drive pressure the valve opens and she has full flow through a huge charger?
Supra guys have been doing it for a while on those little 6 bangers with GT47 and 55 size turbos.
I know of a few diesels that have these quick spool flanges, they seem to like them really well. It will help with quicker spool up on a larger charger but it doesn't do anything for high drive pressure at RPM/
I have seen those before. Good idea. I wonder how they handle diesel soot. The other issue is that you would need to put an undivided spacer underneith it or you would one side would have no place for it exhaust to go.
Has anyone heard more about these custom garrett turbos from precision turbo? I like the sounds of the 3" gt42 cover mated to the gt45 turbine side. I also have been keeping and eye on these bullseye power S400's!
What do you mean? I'm not talking about a blocker flange, but an actual valve that closes off one side, then opens it for full flow at a given point. Shouldn't hurt drive pressure one bit.
That's the exact part I was talking about. I didn't say it would have a negative effect on drive pressure, only that it wouldn't do anything for a drive pressure issue at RPM. Which is what some of the guys were talking about. Sorry for the confusion.
Yeah... but if you're running a T6 flange GT55 I don't think drive pressure will be on your list of problems.
how can that work on a divided pedistall like we run , it looks like it would close off all flow to the cylinders on that one side of the motor
Correct, you can not use a divided inlet/header. It needs to be completely open prior to the valve.
These guys run lots of leaded race fuel through their cars so I don't think diesel soot would post too much of an issue.
If you're curious give Chris @ sp a call. He's a good guy and i'm sure would be interested in testing some out on diesels, if it will fit.
