Info: Big money Pull Frankfort, IN July 15th
aggar
Still Learnin!
Mar 9, 2008
444
Kirklin, IN
Friday night July 15th we're having the 3rd annual Clinton County Diesel Truck pull. 2.5, 2.6 and 3.0. I will post payouts and rules later on in the week. This will be a pre-register event. Just to get your name on the list to reserve a spot. Last year we ran 66 trucks in 3.5 hours. So we're thinking closer to 80-90 trucks hopefully. I'll let you know more details as soon as I get the rest of the sponsors nailed down.
aggar
Still Learnin!
Mar 9, 2008
444
Kirklin, IN
OK here's the rules and Payouts. IF you meet ITPA, COTPC or BOB rules thne you'll be ok but we will be teching trucks and if you don't meet the rules then you won't pull. Trucks in the money will be reteched after class.
$30 Hook fee non refundable if you don't meet tech.
Payouts are as follows
2.5 1st $1000, 2. $700, 3.$500 4.$300 5.$200 6.$150 7.$100 8.$50
2.6 & 3.0 1st $1200 2.$800 3.$500 4.$300 5.$200
Workstock/2.5 rules
Work Stock Class –
True 2.5” Inducer Bore NO CLIPPED WHEELS / NO BUSHINGS/ NO TAPERED COVERS
.200 MAX mwe Groove
No Hanging Weights (Ballast Permitted)
8000lb Maximum (With Driver)
26” Hitch Height
DOT Tires
No Dual pumps, no compressed gases or Power Adders of Any Kind
Diesel Fuel Only
Traction bars are allowed
Valid Registration and Proof of Insurance Required
Single Wheel Trucks Must Run Single Rear Tires, Factory Dual Rear Trucks are Permitted to Run Dual Rear Wheels
‎2.6 Class Rules.
Hot Street
2.6” Inducer Bore
Minimum 1/8" Protrusion Into Bore
Compressor Blades Must Be Perpendicular to the Shaft
.200 MAX mwe Groove
Hanging Weights are permitted within 60” from axle CL
8000lb max (With Driver)
Driveshaft loops, u-joint shields and bump stops required
Dual pumps are permitted
No compressed gases of any kind
No Water/Meth
26” Hitch Height
DOT Tires
‎3.0 class rules
Super Street -
3.0” Inducer Bore
Compressor Blades Must be Perpendicular to the Shaft
.250 MAX mwe Groove
8000lb max (with driver)
Water Injection Permitted No methanol
26” Hitch Height
DOT Tires
aggar
Still Learnin!
Mar 9, 2008
444
Kirklin, IN
Correct. 3.0 can be open and 2.5 and 2.6 are 1 ton or less factory chassis. Should've specified. Still have some spots open.
SmokeShow
6,818
Lawrenceburg, KY
Without licensing it?
I suppose if the truck were already licensed & insured & u stopped paying to license it, the INS would be none the wiser & as such, you could keep the INS on it.
IDK, just seems unusual to req it on dedicated pullers. They're suppose to have event INS to protect the parties involved in any accident on the grounds during the event. Or so I thought??
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Yeah, it does seem unusual, but ive seen a few pulls like that lately, and yes, i carry comp without licensing it, i even change ins. companys and they didnt have a problem with it.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
You don't need to license It to get insurance. Just call with the vin.
When I first bought the puller I put a temp tag on it and insurance and drove it to a few pulls that summer. Then started the build process and it has never seen either since. I still have the luxury to do that if needed since it has a clear title. Some pullers can't.
That said, the rules look like the same as fleeces last pull and I said the same thing about the insurance and tags for 3.0. You want a good 3.0 class ditch the rule. And if you check 2.6 you'll DQ 3/4 of that class.:D
2,022
Do you have to have an air shutoff (guillotine) in 2.5 and 2.6?
Is smoke allowed in 2.5? (Our workstock organizers sometimes say "smoke shows it isnt stock".)
Can you run more than one class with the same truck?
aggar
Still Learnin!
Mar 9, 2008
444
Kirklin, IN
Do you have to have an air shutoff (guillotine) in 2.5 and 2.6? Not in 2.5 but recommended in 2.6
Is smoke allowed in 2.5? (Our workstock organizers sometimes say "smoke shows it isnt stock".)Smoke is allowed
Can you run more than one class with the same truck? Yes you can run 2 classes if you're signed up to run 2 classes
These are fleeces Rules. IF you meet BOB, COTPC or ITPA then you'll be ok.
