LBZ: Best single turbo for daily driver
brandon06dmax
the reckoning
Apr 29, 2013
365
jactionville nc
Is say do a 475 but with any bigger single tuning is key not just ecm but tcm aswell mine was a lazy pig on the highway but its been returned and I'd say talk to Dustin at diesel addiction he is a big single guy or Steve at ss diesel tuning or Caleb at blackout
AUSDMAX
AUSSIE DURAMAX FANATIC
Mar 21, 2013
97
thanks bud ill try send them an email
prodiesel804
Feb 1, 2013
147
Ky
i like anything from a 464-83 .9 to a 475-83 .9 depending on what power you are looking for and how heavy you tow.
AUSDMAX
Mar 21, 2013
97
i might go a S467 billet with a race cover and a 83 .90 rear housing i think
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Bullseye TCT s466/87/.90
I'm a fan of the larger turbine to utilize more exhaust energy. With the smaller compressor it will light real quick and not fall off on the top end. They make a hell of a sound too. :)
carpenca
Dec 17, 2010
168
So for 600-650 RWHP, stock injectors, and stock bottom end, we are going to recommend turbo's capable of 800-900 RWHP?
To believe that you increase compressor size 12-15mm over stock, turbine size 21mm over stock, and increase rotating mass by the pounds and not add any additional fueling mods to offset it, will yield good results without serious sacrifice is ignorant. It is not opinion, its not magic, its not who builds better turbos, its science and math. You increase the size and rotating weight, but don't increase the energy to drive it, it will be slower to spool in every situation, especially under load, and will take longer to peak.
AUSDMAX: Pick a turbo for the power range you want to operate in. A stock fuel system, whether LB7, LLY, LBZ, or LMM is only going to supply enough mm3, cubes, or actual quantity of fuel for 575-625 RWHP, regardless if you have 63mm Turbo or a 83mm turbo. Diesels are simple they make power with fuel and air. With a limited amount of fuel (mm3) an excess of air, is not going to make more power. With a single, an excess of air do to an oversized turbo, will cost low end response, poor "lugging" characteristics under load, and a peak number at a higher less accessible RPM. The difference between a 63 & 83mm turbo is the shape of the curve vs rpm. TURBOS SHAPE CURVES, not tuning, not injectors. Its the turbos job to determine where and when you have power. A larger turbo WILL move the curve right on the graph, incrementally with size, pushing your "power band" further and further out of your normal RPM operating window. Its math not opinion! The bigger the turbo, the longer the delay, BUT the bigger the hit when it lites.
Caleb
Dirtymaxx03
3,109
No boost I can kill people people on the hwy. 42psi and there's nothing coming out of the tailpipe.
s472/83/.90 and Rob Coddens tuned it.
