Best place to buy Drive pressure gauge??
custom8726
2,784
Upstate N.Y
As the title state's, were is the best place to purchase a drive pressure gauge?
All of my other gauges are Autometer phantom white face gauges and I would like to stay with that style if possible. Also while on this topic any suggestions on the best place to install the port (For accuracy) would be appreciated.. :hug:
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
I run all isspro EV2s. Mine is a true drive pressure gauge (face even says exhaust back pressure) I plumbed it just forward of my EGT probe using brake line and a 1/8" NPT fitting
1,862
Does Autometer allow for custom faceplates? I could not find a dedicated "DRIVE" gauge in the styles I was looking at.
I just planned on using a Cobalt Digital with the blue numbering for drive to contrast the red Sport Comps I already have.
custom8726
2,784
Upstate N.Y
Ok, how crucial is having a drive pressure gauge in dialing in twin turbo's :confused: A most have? or optional? I have a 35psi and a 100psi boost gauge now.
HogAssWild
Nov 12, 2009
502
You will def. Need the 100 psi for drive pressure...
I'm no tuner but drive pressure does play a big part in wether ur engines gonna pop or not:thumb:
I need to get my d.p gauge hooked up also
Big Angry
<--My idea of a good time
Sep 3, 2006
406
South Central Pa
I just run an autometer Pro Comp II 100 PSI boost gauge, exactly like my 60lb boost gauge, only used for drive pressure. Mark at Danville installed it when I was in Indiana last year. He even plumbed in a filter so as to keep the soot from clogging the line, used a lawn mower fuel filter, pretty slick. :D
custom8726
2,784
Upstate N.Y
HMM, sounds like a good idea. I might have to try it:thumb:
LEVOY02
Jul 16, 2007
Northern Illinois
I've been wanting to do a drive pressure gauge as well, but I was thinking that a peak recall gauge would be best for that. Anyone know where to get one? Isspro said they didn't even make them when I talked to them at schieds. Sorry for the hijack.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I'm going to put mine in the passenger up-pipe. I made a block off plate for the egr. & drilled and tapped it. Do you need one full time? I was thinking of just using a temporary one during tuning?
