Best Oil??
swinters
Journeyman Mechanic
Oct 3, 2011
Western WA State
Good to know. Thanks. :thumb:
Are many using Rotella T6 and is it working well? I'm thinking it may be the best option for me. Over the years I've run a lot of different oils and generally prefer Eastern oils (paraffin base) such as Kendall, Pennzoil, or Quaker State when it comes to regular oils but am not as specific on synthetic oils. I really like Kendall but it can be a pain finding it when you're on the road. A lot of people I've talked to like Rotella T6 and it can be found almost anyplace that sells auto parts, even Wal-Mart, so getting it is a piece of cake. If I remember right, the owner's manual says 15W-40 at warmer temperatures and 5W-40 at cold temperatures (don't have the owners manual in front of me so that's from an old dudes memory...). The dealer says it complies with warranty requirements. Shell seems to only sell the T6 synthetic in 5W-40 and their application page says that's their oil to use in my 07 Sierra Classic (LBZ) at all temperatures. Over the years I've had a lot of training and experience with oils and other lubricants but all directed towards the Heavy Duty Automotive and Construction fields and it makes sense that the viscosity improvers and additives would work fine. Probably the only difference is that if someone was running extended intervals and oil analysis they'd get a shorter oil life on a 5W-40 than a 15W-40 (generally speaking, the wider the range of the viscosity improver the faster it breaks down towards the base oil weight). That being said, I'm not a Duramax expert and would like to know whether people using Shell Rotella T-6 synthetic in their Duramax are pleased with it and any additional insights.
IronDX
213
My main thing was picking a engine oil that I can get cheap in price, & finding it was easy. I like Mobil Delvac 1300, & Rotella T, because of those reasons.
mkzfxdf
Aug 28, 2013
Charleston, IL
Lubrication Engineers LE. I think they may be the original high performance high mileage lube company. If you can't get 15k to 20k between oil changes then something is wrong. It doesn't cost any more than Amsoil or Royal Purple but you get twice the mileage.
My dad used LE lubes in his '73 Bronco sport back in the day. It was his daily driver and he raced it at least once a month and drove it to Land Between The Lakes in Kentucky 2 or three times a year. It's all sand and water down there. When he and all the other driver would get back home the other drivers would have to change out all the filters and lubes but my dad's Bronco was always good to go.
To get 20k plus between oil changes is not uncommon with this stuff with a diesel.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
We have 18 dmaxs, several 6.5s, 6.2s , cat loaders, john deeres, and several mack trucks, ect out here on our ranch and everything runs Mystic 15w-50 synthetic blend, hell even our lawn mowers lol. We have sent off oil samples between the top brands of oil and it came back with great results years ago. I'll never run anything but Mystic in my truck as we've ran it since the late 80's out here. We've bought a couple of dmaxs that has rotella when we got them and its amazing how quiet it gets when mystic goes back in her. It has a great cushion even after heat and time. Ill see if I can find the results and post up a pic.
