Best Mileage Turbo
05chevy
1,086
I have went 3 tanks now with my single 475 and consistently get 19.5mpg around town. And thats even climbing a mountain.
Mikey
Drag Racer
Jun 13, 2009
560
3
Anybody with results from bb chargers?
Mileage on a PPE compound setup?
gmduramax
Shits broke
Jun 12, 2008
4,086
254
Nor cal
My mileage dropped when I went from my stock turbo to my S475. I'd say a ball bearing turbo as a single would get the best mileage.
Mikey
Drag Racer
Jun 13, 2009
560
3
Aren't the 4094R's known for high EGT's? I thought the exhaust side wasn't setup very well
Are they? I couldn't tell you. Maybe when making big power. How about for mileage? And then compound it and your egt's go down. Maybe Dan from PPE could tell us?
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
my 4094r ran hot as balls. significantly more top end than my 4088r nut also spooled much slower than the 88 as well.
DieselmafiaLLY
Keep Calm and Go Crazy
Apr 6, 2013
1,102
Ontario, Canada
you guys should look into comp turbos, they can come with ceramic bearing which from what im told spool quicker than the regular ball bearing ones....buddy is getting one to use in his triple kit on his dodge
Mikey
Drag Racer
Jun 13, 2009
560
3
They have real good prices too.
I've heard they use their own ceramic ball bearing center sections, turbine & compressor wheels but similar comp and exh housings as both Garrett and Brg Warner.
I am looking into a single for now.
Mikey
Drag Racer
Jun 13, 2009
560
3
Aren't the typical center sections made of cast iron? They use aluminum. Would that be ok? Correct me if I am wrong.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Both my chargers are by Comp with the aluminum ball bearing center sections. So far I have no complaints. Only thing I'd be worried about is stripping out the aluminum if your constantly changing/removing them.
Mikey
Drag Racer
Jun 13, 2009
560
3
What kind of power are you making. I was thinking of getting the Ball Bearing 72 to start with like you have listed there. Did you ever run the 72mm Comp Turbo as a single? Any Numbers? How does it compare to other chargers?
And what do you mean by captain lag? I thought with the setup it should spool decently? But what do I know?
Thanks!
DieselmafiaLLY
Apr 6, 2013
1,102
Ontario, Canada
Thanks!
your best bet for quickest spool would prob be a billet 72 with ceramic bearings and run that as a single
