I had the 4094VVT and towed 10.5k with it quite a bit. It did alright...
EGT's were quite a bit higher than I would've like to have seen and in the end I believe the 4094 was the most of the reason I got a hole in my #8 piston.
I got the hole after switching to the VGT72, but I believe all the time running the 4094 hard and having massively excessive EGT's started the damage.
That being said, I now have a stg2 3794va from Mark, and I'm truly impressed with this charger. Currently I'm running my old tuning for the VGT72 and even with that tuning the 3794 is hands down the best charger I've had!
EGT's are way less than I've seen with any other charger, including stock, I've pushed the big tune a little bit now and I've yet to see the EGT's above 1250*
This charger spools very fast, has a nice broad power curve and delivers a nice hit that just keeps pulling. It hits harder than a 4094 but not as hard as the VGT72 but maintains EGT's better than either ever did.
I can only guess at this point that it will be an excellent tow charger. I can say that the turbine break is far better than that of the vgt72 or the 4094vvt but not as good as a stock turbo. To try and put it into perspective, the stg2 3794va's turbine break in the heavy tow tune is about the same as the stock chargers turbine break in the light tow tune, but like I mentioned, my tuning isn't optimized for this charger yet so that may change for the better...
All and all, I really think that the stg2 3794 is THE CHARGER to have if you're going to run a performance VGT and I really couldn't be happier with it!
It's a tad quieter than the 4094/VGT72 but it has a very defined and distinct whistle that doesn't disappoint, trust me, you'll know it's there
:thumb:
