Best batteries for performance and price.
kubitza123
Sep 19, 2016
144
Texas
I use the Duracell ones from Sam’s . Only $127 and 2-3yr free replacement . Best part you don’t have to deal with leaking acid.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I just had two red top Optimas replaced under warranty. They didn't last a year and a half. The OEM batteries lasted 9 years under the same conditions. (infrequent driving) If I had to do it over, I wouldn't have bought the Optimas. Too expensive and it seems like there are a lot of other less expensive options that are just as good or better. Good luck!
All new optimas are inferior to the ones made 10 years ago. I had a set of red tops last almost 12 years.
In all reality there are only really 3 battery manufactures in the world and all agm batteries are made the same way so you really can't go wrong just find one that has at least a 3 year warranty.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,239
383
At Da Beach
Old thread...
I just got Duracell batteries for my truck from sams club. The AGM Duracell are made by Deka aka East Penn manufacturing in Pennsylvania.
If I remember right CAT batteries are made by Deka also.
East Penn = quality batteries
I use them, Northstar agm or Oddessy only. I sell ALOT of batteries so I'm picky about what brands bc I hate getting a call back on one. I think I sold a little over 400 last year...:spit:
torqued2dmax
646
Brookville, PA
It looks like the Deka East Penn AGM 30 month free replacement 9A78 for $175.51 , picked up at one of their warehouses , looks like a good one , 775 cca ! Manufactured in PA ! Or their lead acid 778 series 30 month 800 cca for $105.22 !
ZeroGravity58
1,401
51
Maryland
If you are familiar with batteries do you have any idea what is the biggest Odyssey battery I could fit in the stock drivers side tray would be?
hatsoim
MR
May 11, 2018
3
Iowa,Des Moines
I had a powerstroke . I put everstart in they failled. I put two optima yellow top they failed . $400 dollars waisted . thought something was wrong with chargin system changed altenator . glo plug relay thinkin it might be that draining them wasnt those things either. Finally went with interstate workaholic cured all ills made the battery gauge go even higher than when the truck was new and I sold the truck a year ago and they are still good after six years . When I purchased my first cummins used batteries went out bought insterstate they are doing great too.I also have 2 Red Top's https://mechanicguides.com/best-batt...diesel-trucks/ in my truck they are 2 years old. We get very cold weather here I have never had a problem with them. In fact, my wait to start light has always been faster and it cranks faster than the original batteries. I gave a 9 year old red top to my friend with a old Cougar, its still works like new. One of the biggest problems people have with batteries is they don't replace both at the same time. You need matching batteries otherwise one will be pulling more current all the time. I have heard of the people having issues with red tops but it is a misconception, most of those problems were related to poor cables and or grounds. You need at least a 650 cca at low temps, most batteries are rated around 40 degrees.On YouTube there are a lot of interesting videos on this topic,check out this, I hope its help you.Good Luck
https://www.youtube.com/watch?v=1i01V2DLjiM
