Trying to wire in bed lighting in my 06. Power and ground run up under hood. Power leg run to a relay, ground to frame. Pulled power for relay from the fuse box. Here's the fun part...... Went to run my switch trigger from the cargo lamp switch and it works on a ground. Power to the cargo lamp switch is constantly on but when the switch is pushed, the power on that line goes dead.
Anyone have an idea how I can tie this wiring into the cargo lamp circuit without pulling all the wire back and tearing the truck apart to find the constant to the cargo lamp itself??
I want the lights all on the cargo lamp switch ....that, and the bcm has a timer so if I forget they're on, it'll shut off after a delay.
