BD @ N20 = Ouchy
BADDZL03
Piston Cracker
Mar 8, 2007
52
Indiantown FL
BD Turbo Shaft after Sled pulling and shooting some Juice. Weight was about 6900lbs at the time. Needle on the 35lb boost gauge was hitting the needle on the other side. I believe I had thrust bearing failure. The BD people said it was bearing failure due to contamanated oil. Thought I let everyone have a look at the carnage. Time to go a little bigger.:nanawrench:
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
Wastegate? Maybe a little too much boost Brent. Thrust bearing failure is normally due to excessive drive pressure and/or overspinning it. I have a little experience in this area:(
That charger was making a lot of power. Time for a second pump and a set of twins:D
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Sorry about your turbo
Are you backing the boost down when you spray the NOS? My opinion(for what that is worth) you need to back down the boost when spraying. You don't need it, the NOS will add the air without all the heat. I am trying something new for the diesel power challenge and if it works like it has so far its pretty cool!(pun intended) I will let everyone in on it after the event.:D
BADDZL03
Piston Cracker
Mar 8, 2007
52
Indiantown FL
It did hold the 2 hour drive back to the house:eek:. I have one of the most expensive BD's out there I have about $3300:ban-hump: in that charger.
C.A.P
Feb 16, 2008
103
Contaminated oil ! :rofl:
Maybe lack of but not contaminated ! Typical BD :confused:
BADDZL03
Piston Cracker
Mar 8, 2007
52
Indiantown FL
BADDZL03, do you back the timing down when you use NOS and how much?
I am running Moonshine, Tony made me up a nitrous tune that takes out a little timing and adds a little more fuel. I can back the timing a little more because of my larger injectors. I would say 2-4 degrees would be my guess.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Baddzl03
Thanks, I had a hunch that timing was being pulled out. I think there is a fine line there. I think you will find out that many with a BIG turbo adds timing. I feel you need it with the extra air and or fuel with higher RPM. Thanks Jeff
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
I know the bd has done very well for u in the past. What options are u looking at now brent?? A a5k a6k a7k or a gt serise or htt turbo?
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
how big of injectors?
Sorry bout your luck,But something dont seem right?
How does your turbo get oil? Cam journal? or is it elsewhere?
BADDZL03
Piston Cracker
Mar 8, 2007
52
Indiantown FL
Oil supply comes out the side of the block it's a 19mm bolt right next to the oil cooler/filter assembely doesn't come out of the Cam location like the stocker does.
