I just picked up a BD exhaust manifold and new GM gaskets to install when I do my gauges. Any tips, tricks, or instructions. Just to clear it up this is the driver's side manifold. I need all the help I can get. Thanks everyone.
Should I put anti-seize on the bolts before reassembly?
Seatbelt works great for thisfor the steering wheel, just wrap some masking tape around the wheel and tape it to the dash once your bolts are out, but before you remove the shaft.
have you finished the install? if so, did you notice any difference in performance? Thanks.
