Battery relocation
c55asleep
Apr 23, 2009
163
Miami,Fl
Looks like it would be a PITA to change the battery when it goes bad. Thanks for the pics. Now I know where it goes when I win the lottery and buy some twins.:p
A floor jack will make the job a lot easier. I thought the same thing before I got it done.
03-GMC
Let there be light!!
Mar 26, 2009
485
SLC, Utah
Just got my tray from Gmpartsdirect.com It looks almost identical to your but mine has a little tab sticking down with a hole in it? Did you cut yours off or did yours come without the tab?
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Is this the part number you used 15041310? Also does Nathan send these with his kits or is it an extra?
13,716
779
Yes, the tray originally came with the little tab on the bottom. I used a grinder with a cutoff wheel to remove it and sprayed it with some spray paint.
I installed one of Nathan's new kits at work a few weeks ago, and it came with a tray and parts to extend the cables. I'm not sure if it was extra or came included in the regular price or not.
03-GMC
Mar 26, 2009
485
SLC, Utah
Cool thanks Josh :thumb:
rebel7777
Diesel Head
Jan 15, 2010
97
Sherwood Park, AB Canada
If I installed mine in that location, it would be covered in mud and I know I would have battery failure at that point. Used to have a dual oil filter mounted there, kept breaking lines.
Where else have people mounted the batteries on these trucks?
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
Mines mounted on the passenger side frame and we managed to get it all hooked up using the original battery cables, they were plenty long enough without splicing :D
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
did you just use like 4 gauge wire when you lengthened those?...i dont have twins but i would like to relocate mine just to help with the horrible weight distribution these trucks have
kjp800
Aug 6, 2008
525
New Jersey
depends where you want to put the battery, if you put it where most do the cables will reach without lenghening
kenny
kennydiesel
Mar 5, 2009
319
washington state
I just picked up one of these battery tray's. The part # 15041310 is a good number currently with any GM dealership and the application is originally for factory equipment on the van model. :)
