Battery not charging appearing on my dash?
Jul 24, 2013
174
11
jacksonville nc
Okay here's what's going on.
I just swapped the banjo washers on my lb7's return line and I just got it back together. I think I hooked the wire that is on the back of the alternator up to the wrong spot. I have it hooked up to the glow plug module now, where I thought it should be. Please correct me If I am wrong
04 Lb7 cc/SB new guy to the forum
Jul 24, 2013
174
11
jacksonville nc
I checked all the fuses and they are all good eery thing is plugged in, also the heater only blows out of the dash, no defroster or floor heat and when I move the temp control from hot to cold I don't get any difference, the only thing that works is my 1-5 blower control switch
5,911
do a HVAC relearn and it should fix the issue.
pop hood and pull HVAC/ECAS fuse
put key in ignition and turn to run for 15 sec then turn the ignition off for 30 sec making sure you dont touch anything
put the fuse back in and start the truck but DO NOT TOUCH anything on the temp controls, blower motor, or air direction settings for a full minute
that should recal the HVAC and fix your issue or most of it if all is hooked up right lol
Jul 24, 2013
174
11
jacksonville nc
Will try ASAP, yea I should have everything hooked up properly I double checked everything this morning when I got to work, and it looks like I got everything where it needs to be.
