Has anyone done this? How do u like it? What kind of benefits did you see from the switch? Please reply, thanks
I will be buying one and run it in my twin setup. Ill be interested to see how it does if it will allow more air flow from the big charger
James, do you know what the install takes? Im sure it would take a turbo shop to install and do a high speed balance correct? Whos going to to this for you?
I thought the wheels came pre balanced?
I would imagine they are. Im sure they will just drop in place. My billet wheels on both turbos just drop in place other than having the backing plate machined but that is because the are also bigger.
I have no idea what droping one in takes. SO is this a DIY upgrade? The other thread wasnt the most clear about it
Ive never done one of these specifically But i would imagine that you take the down pipe off and the compressor cover off put a back up socket on the turbine wheel and unbolt the compressor wheel and then put it back together with the new wheel.I have no idea what droping one in takes. SO is this a DIY upgrade? The other thread wasnt the most clear about it
