Banks Top Dragster assembly photos
jbarker@bankspower
<Worlds 2nd Fastest Dmax
Mar 24, 2008
390
49
1. I see two Fluidampnrs sandwiched togather....whats the reason?
High RPM damping. One won't get the job done.
2. I also spotted the air line to the shift valve on the wheel, what tranny ya usin, Lenco? If so, clutch or Bruno?
It's a Liberty extreme transmission, air shifted, magnesium case.
3. Nice digital dash! Who makes it? EFI Technologys
Appears to have sequential LED shift lights?! You bet
4. Whats the black knob/hex shaft on the right side of the display?
That's the reverse lockout
5. Whats the squarish "puck" stuck to the chassis tube in the E-box? GPS?
GPS
6. Spitzer slip-tube chassis?
Yep. Certified for 6.50 and slower
7. Whats the round units w/hard line clamped on the rear of the chassis near turbo area? Those are dryers for the back/drive pressure sensors for the turbos. They're mostly for cooling rather then drying however.
8. Beautiful CP3 mountings! Gonna Cog/Gilmer belt drive them?
Gilmer
9. Wow! 7-Stage dry-sump oiling!
With -12 lines
10. What brand/type of braided line is that, I'd like to use that on a project of mine!
Those are from XRP
No problem:D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Thanks for more pictures! :hug:
Is there a third CP3 in the valley?
Or will it use two that can be timed?
One thought I've had is what the effects of "timing" CP3's would be. It is difficult because they are 3 shot pumps. But can be done. Everytime an engine piston comes up on the firing stroke, you could have a CP3 piston doing the same, or 2 CP3 pistons doing the same with multiple pumps. Stock the pump goes at crankshaft speed so it pushes fuel out 3 times while the crankshaft fires 4 cylinders. So if you regear the CP3's so they spin 1/3 rd faster, every time an injector opens there is a high pressure wave coming from the pump(s) to keep the fuel pressure from dropping off.
This can't be done with a conventional belt, or at the stock pump location. Only a toothed belt or other timed mechanism would do. But it would be a very expensive experiment, with no guaranteed increase in power.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Man that is cool, but how is there no dirt in that shop? That almost pisses me off I can't keep my shop clean for 10 minutes let alone an entire 1 off build. Ahhh.. I just drooled on my keyboard
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
Thanks for awnsering my Q's! Cool, cool stuff!
Pat, your timed CP3 idea sounds great nosee how it could hurt? Since there gonna be Gilmer-belt drivin, they could be timed. :cool:
jbarker@bankspower
Mar 24, 2008
390
49
Trans, clutch and rear end are in:
slowlmm
Mar 2, 2008
2,582
46
so cal
verry nice. I have question what if any matinenece will have to be done after every run comapared to a top fuel car?
jbarker@bankspower
Mar 24, 2008
390
49
Very little at all. They'll check the engine over, cunch the numbers from the data logger, check fluids, add more diesel fuel to the cell, refill the nitrous bottles, and run it again.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
sounds great guys ! ..... did they swap out the intake runners ? the ones in the pics are powdercoated red , and the ones in the vid are not ?
