Banks dragster testing video!!!
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
:D Awsome Job Guys! Looks like in the last pass, it started to skate a lil on the big end!
That Liberty is much smaller and lighter than a Lenco. The 3spd in my signature is a hefty SOB and still 2 more gear sections are needed for 5spd operation. And yes, it would be quite long.
I plan on using the one below in my truck. The Lenco is stronger but just not applicable for Banks rail, IMO
Perhaps they'll comfirm that:D
Smokin LB7
Jul 25, 2008
191
You guys are trying to pull something arent you!?!?!? Theres no smoke!!! That cant be a big, clunky, smoky, air polluting, global warming causing DIESEL could it???? Al Gore would be so proud. :joker:
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Does Al Gore support the use of nitrious?
Accelerator
On a Time Out
Mar 12, 2009
242
With the magnesium cases, and titanium shafts and light weight clutches and drums, a Lenco 5-speed would be within 25lbs, and handle 3x the TQ. + there much faster to work on and replace parts if they do break. Also lenco has about half the paracitic drag a liberty does.
jbarker@bankspower
<Worlds 2nd Fastest Dmax
Mar 24, 2008
390
49
Once again guys, the trans didn't fail because of too much power, it failed because the shift lever retaining spring broke off causing the trans to try and go into 4th and 5th gear at the same time.
mytmousemalibu
Apr 12, 2008
2,230
Kansas
Well the CS-1 out im my shop is magnesium cased, the shafts are Marage iirc. The CS-1 is there bad@ss super-stout one, it was in our 69 Nova Pro-mod. Even with the mag. cases, shes a heafy beast! Im not positive but the lightweight parts are for CS-2 and CS-3's. Smaller and lighter than ours, but hold less power/torque.
They are really simple, and easy serviced! Good ole planetarys for ya! Kinda like a super simplified, fully manual, auto tranny.
Accelerator
On a Time Out
Mar 12, 2009
242
Yep and lets not forget the titanum can weights about 30 lbs less than the steel one two. the difference between the mirage and the titanium shafts are about half :D
Accelerator
On a Time Out
Mar 12, 2009
242
Thats a dual frame rail car there... pro mod?
mytmousemalibu
Apr 12, 2008
2,230
Kansas
Yup! Pics in my profile/album
Unfortunatly we had to get out of it, we traded the car as a roller for another 69 Nova turn-key, its a low 10's-high 9's.
But we still have our motor! 526ci Arias/Fontana hemi, basically a top alcohol motor;)
Accelerator
On a Time Out
Mar 12, 2009
242
Titanium parts in general are 1/3 lighter last I remember. So you are saying the steel part weighs 90lb?
Accually they(steel) weigh about 80 lbs, and the difference comes from material AND metal thickness. Because Titanium IS also stronger than steel, they can build them with less wall thickness.
Thats were the weight reduction comes from.
Accelerator
On a Time Out
Mar 12, 2009
242
Yea, those motors are the shiz nit.:cool2:
jbarker@bankspower
Mar 24, 2008
390
49
Did you guys run at AZ today?
We did run it, and she ran REALLY well :happy2:. However, I'm not allowed to say how well yet:denied:, and Gale is standing behind me with a gun to my head.....an announcment will come out later today.
serpa4
Feb 5, 2007
402
That much power and no smoke, sweet. Need a larger turbo, more boost, to clear up mine. Stock sucks, but the mfg warranty doesn't.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
:toetap::toetap: ..................... we will be anxiously waiting :D
