Youd guys hate me.. I change my oil every 500 miles.
I do actually hate you just a little bit... but I guess you're forgiven since petro Canada is raking it in and they're a decent company:spit: Truth is you might be doing more harm than good changing it that often. Sometimes the ISO particle count in the wear metal causing range is higher straight out of the bottle than used oil after a couple hundred miles with a solid filter. I understand some people can't make it that far without trying to get a peek at how things are going in there though...
@WorkingTruck You can go way longer with T6... at least run out to 0% on the oil life monitor. I understand it feels wrong, but I promise its ok. If you want to do right by your motor you may see more benefit to changing oil less and putting the savings to a sweet filter like a Mobil 1 303. The 17micron single pass rating beats the pants off of most filters out there and may make a statistically significant difference in your wear metal levels.
Switching around oil brands with very different additive packages can actually cause a spike in wear metals as well... its a strange phenomenon whereby engines become accustomed to whatever anti wear packages you feed them, and they may not like a sudden change from a molybdenum heavy oil like Delo to a low or no moly oil like T6 or AMSOil.
Also in my professional opinion Schaeffer's rules, and no I'm not a dealer and get no discount.:thumb:
