Other than injector failure, what are other reasons for high balance rates. Bent rods, worn rings, bad valve seals, etc..?
I had a balance rate of over 8 and what sounded like injector rattle. I had my injectors sent back to Exergy and they said everything checked out OK. My next step is put a set of stock injectors in that I have in and see what happens with the rates then. I also thought of doing a leak down and/or compression check.
Any thoughts or ideas?
Thanks all for the help!
