I just bought a 07 LBZ dually with 200K on it. One owner, meticulous maintained. supposed to not have any tuning on it.
Unfortunately it smokes black bad from about 1/2 throttle on.
So far I've checked for boost leaks, confirmed idle and WOT MAF and MAP readings on another LBZ and they are very very similar. Both desired and actual FRP's match (within a few hundred psi of course).
Truck also has fresh oil & filter, fuel filter, and air filter.
Truck does has full factory exhaust with active EGR which I will block tomorrow.
Also, no blow-by at all that the factory PCV system does take care of at idle.
If anyone can help diagnose this it would be greatly appreciated.
