LBZ: Back from the dead
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
I just got my truck back a couple of weeks ago and I've put about 400 miles on it how long before I should re install a tune or should I just give up and go back to gas?:confused:
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
I didnt do anything to it . Well as you know I tuned it with a PPE standard and played with it alot ( switching between tunes 1-4 ), but never got crazy.I ran for a year on level 3 no problems. Last feb I took it in for a brake job and a Jr kit, and I asked if my mechanic would give it a once over because he was also installing a shim kit and lift pump. He said he saw where a small amount of fluid had been evaporating from the rear of the passenger side head so he pressure tested it and it was a little pin hole trickle so I took it to the dealership and got it fixed but it took two and a half months to get it back do to the fact that the gaskets were on back order. It was only an externall leak my heads tested good and no internals were damaged. Everyone I have talked to said it was just probably gasket failure and not performance related because ther are guy's putting way more power to their trucks and running fine, besides a d-max top end is good for 600hp right its the bottom end you have to worry about. any how correct me if I'm wrong let me know if I can run my tuner again and if I should take baby steps or tune it right back to level 3:happy2:
paint94979
Beer Nazi
Sep 18, 2006
11,715
37
Turn the PPE up you will be fine. Good Luck
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
One more thing , I guess it had a grade A on the driver side and grad B on the other and now they are both B's , Is this Okay? P.S besides tranny upgrades the motor should handle 500rwhp right I didnt put to much to it did I?:confused:
ripmf666
15,123
14
47
Wentzville Mo
Level 3 is not going to hurt the truck,I always ran level 6 on the Hot+2Et everyday,with the head gaskets being 1 grade a and 1 a grade b did you buy the truck new or used ? should of had the same on both sides.Post your vin in the vin check area and we can look at the history of your truck.
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
Thanks for the feedback. I can live with level 3 it runs pretty good . After I get the jr kit installed and some fuel rail tweeking and my lift pump , I should be able to run level 4 on my tuner right? , or am I asking for it. I just dont want that to happen again.:) I've got to change my sig because my block plate and boost increaser are still in a shoe box with the jr kit and all my other goodies( I'm kinda scared to install everything now after the gasket problem):confused:
