B & B Carnage
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
39
Locust, NC
I have heard of guys running bogger backwards with a bunch of air in them on the road until almost bald. The tire when reversed will look just like a cepek cut pulling tire. I f I had the money I would try this
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
Be prepared to have all B&B faburacations done including axles before u do this. I done this and it taught me a big lesson. A stock turbo dmax that only dynos 300 hp can snap rear ends like there penciles also.
ripmf666
15,123
14
47
Wentzville Mo
I was thinking of running a set of the claws and having them filled with calcium chloride or the newer stuff that is out , since most areas here will not let you hang weight.Here is some links
We are pleased to announce the next generation of loaded tires, Rim Guard. Rim Guard is a nontoxic, biodegradable, non-corrosive fluid that we use instead of calcium chloride. This product is roughly 11 pounds per gallon and will not corrode the rims. We have been using this product for almost 2 years and we have been pleased with the results. The cost is similar to calcium chloride when labor is factored in,
http://www.rimguard.biz/Products.html
http://salesmanual.deere.com/sales/...performance/7020lf/7020lf_ballast_liquid.html
dmax tim
just wanta have fun
Aug 16, 2006
215
35
Freddyville, Ohio
I ran loaded tires on the front of my hoe, it had 14x17.5 ground hogs. even the 90% doesn't add that much weight and since your tire is smaller, don't know if it'll help much.
542
these have been ran backward for a while in the sand.
on side is round the other is still very much cupped
this is a pic of a 35x15 r15 bogger and yes a 15" rim fits on the rear end ;)
ripmf666
15,123
14
47
Wentzville Mo
Most tracks here will not let you hang weight,must stay street looking, I was going to install my plow mount and add some lead to the back side of it.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
That's an old tractor trick as well. Reverse burnouts on concrete work too.:D
I have a set of worn out boggers/parts pitchers that I have grown attached to. they were on my 78 until I put it away and started working on the puller. Actually one is nearly brand new as boggers like to dig and I found an old plow cleat on the trail I was on and sliced one beyond repair. Now they are being used to roll around the project truck - note the direction of the right rear ;)
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
39
Locust, NC
I wish I lived close enough to have a hand in that build, I am jealous
05smoker
Mar 30, 2007
2,379
Lebanon, OH
Mitch, look at a picture of a bogger and then just cut off all the little tread bars and leave the big ones, This is how most guys cut boggers.
i will try to find a pic
My cousin uses a sawzaw to cut his boggers for his trailriders. Use a metal blade and it will cut right through the small cleat once it gets hot.
Here's a pic of my truck the one time I had the boggers on it in March. I love the tires on my 78, couldn't tolerate them on my Dmax for more than a few days.:D
