Where did you get the fill tube? Made it I assume?
It's the ppe just clocked it and welded a new bolt tab
Looks Great, Any chick would love to loose 10 LBS!!!!
Abby is still a single charger?
What is the smalller water line over the Alt go to?
What is the square tubing on the pass side of the eng for?
Love the low side common rail fuel block you got there...
Would this set up work with a factory water pump?can't see if it would clear.
Can I ask what gave you the weight savings other than the water pump missing?
Notice the lack of the big heavy fan drive pulley and bracket.
