How can you swap form auto 4wd to manual?
I swapped Newly trucks few weeks ago, I had a manual tcase on my LB7 single cab, he has a electronic 4wd case. I would like to put manual back in the truck due to ease at the strip.
I am also converting the truck to a LLY. Swapped the LLY donor harness into the extended cab already and it doesn't have provisions for a electronic tcase.
Cutting a hole in the floor isn't a problem, but I need to figure out how the front end is actuated...
Or, convert the truck to 2wd? Have no problem doing that either, with a big tire in the back.
