Attn: People running ARP head studs
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
It has just come to our attention that ARP has changed the torque spec's form 96 ft lbs to 125 ft lbs.
Thanks to Eric Merchant :D
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
thanks for the info Kat:hug:
Also do you know if you run them for a bit then re-torque
and should a peson torque in steps? like 60-90-126?
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
I don't have a clue but I will find and let you know tomorrow:D
It seems though it would be hard to re-torque them though :eek:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I don't have a clue but I will find and let you tomorrow:D
well ya it would be a total pain in the butt, i just remember reading a couple threads about this issue
Torque them the first time!!
whenever i tourque alot of bolts, I will useally go in steps:confused: and ofcouse use a proper sequence
i would tourque them to 126 before i was done with them just wondered what others do?:)
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
I always have them all Tight and then torque them down to spec. I only have experience with CNC machines and heavy equipment, no dmax's.
9,903
149
Always use a cross pattern starting from the middle and work your way out. Also do it in steps to ensure you have an even displacement of pressure across the surface of whatever you are tightening.
This is a pretty much standard rule to go by when tightening/torquing pretty much everything! Or at least in my world it's my standard and I have never had a problem. Most manufacturer's would probably agree though.
Simon-You need to by about 3 torque wrenches of different sizes-I've seen you work!!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
ARP says to bring the bolts up to spec, then loosen them, then tighten again. 4 Times!
After you do that once, you do not have to do it again.
I'm going another step - I'm polishing the threads with a wirewheel to get even more repeatable torquing. You can feel that the nuts spin freer than unpolished. See pics:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
No, the studs have an allen head, but you are NOT supposed to tighten the studs themselves.
You lube up everything with moly assembly lube (threads, washers, nuts) then screw the studs in finger tight. Well, the threads will hydrolock a little with the lube, so screw it down til it stops with an allen wrench, loosen, then go finger tight. Then put on the washers, then nuts. I'm going 40lb then 80lb, then 125lb per GM ordering, then loosening, and repeating 3 times.
Interesting that the head gaskets come with a warning label that says to ignore the GM book specs and tighten to 60 deg + 60 deg instead of 90 deg + 75 deg. Or in other words, GM wants you to NOT tighten the OEM headbolts as much as before. Interesting.
Nasty Girl
Apr 11, 2008
55
ARP has now released an upgrade to the previous studs 625's are now on the shelf. ;)
Stretched my old ARP's. :(
