That's strange his would be different but I guess you never know. Maybe he was talking about the machined p1 drive flange.
I'm so surprised this has never been discussed before. Wheres Mike did he croak? Knee deep in wool?
Now everyone is discussing kits what about what I have is a full built drop in from ATS? With the Co-Toilet.
what has to be done to a ats drop in trans,to install alto clutchs..What do you want to know?
First of all you will need a stock sun gear cover for the front drum because ATS machines theirs down to fit 7 clutches. I suggest buying a complete clutch kit from either Suncoast or PPE which will give you all the machined pressure plates and proper clutch clearance.
ATS does use the Transgo trim valves but they do not drill the holes in the seperator plate. If you are using the copilot do not drill the plate. I also don't like the hollow pressure regulator valve ATS uses and suggest a stock valve. You can continue to use their pressure regulator spring if you are making 600 + hp but I don't recommend it for a daley driver as it is too much. If you're going with a stock pr valve, you will need a modified Transgo converter flow valve so there is no pressure nockdown on TCC apply. I also recommend a different converter.
What issues might one run into using ATS's valve instead of the stock one?
