ATS atomizer
bigmackmiller
1,046
Kokomo, IN
Go with EFI guarantee it will run/perform better than anything else out there...it allows you to have up to 5 custom tunes made specifically for your application...fresh fuel filter/and a lift pump should take care of your low pressure problems....call so-cal they should be able to answer your questions:So-Cal Diesel 27833 Avenue Hopkins Suite #6 Valencia, CA 91355 Phone (661) 775-5620
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
The atomizer will bring up the high pressure Rail side but if the suction side cant keep up there is no point. Thats what a lift pump does is supplies a low pressure supply of fuel to the CP3 so it is not starved for fuel.
The atomizer will increase the desired pressure but it can't raise the actual pressure unless there is enough volume for the cp3 pump
Also all that crap they claim about it saving injectors is a load of bs
Seriously? I had my hopes up I ordered one now you fricken tell me ,you SOB! :D
