I tried to order arp rocker arm studs for my build and found out that they are no longer making them. Will I need an upgraded rocker stud? And if so where do I get them?
I got mine form Socal Diesel.
I wouldn't say they are a necessity. Cheap peace of mind. Most hardware stores stock hardened 10.9 metric bolts that are of the same if not more tensile strength as the ARP bolts/studs. I've used ARP bolts, studs, and the generic bolts/studs and all work just as well as each other in this application.
BS.
8.8 or 10.9 even 12.9 Bolts DO NOT have the tensil, yield, or shear strength a 190,000 PSI ARP stud does. in fact a 12.9 bolt has only 177,000 PSI rating. It does make a difference.
For you to say its all the same is obvious you dont know what your saying. Please remember some on here are trying to learn.
That explains alot...Tim works with DTS, he knows everything
I was going off what McMaster-Carr's site advertises them as, so if they are wrong, so be it.
Either way, I'll stick by my statement that in that application, they will work the same. They are only torqued to 40ftlb...they are not being asked to hold a lot
