followed them just as the book said.
1st sequence-37 ft lbs
2nd sequence-59 ft lbs
3rd sequence-60 degrees
4th sequence-60 degrees
Also after you hit your last 125 your suposed to let them sit for 24 hours and go back and do a check in order 1 last time of 125 im not saying to loosen them but only to check them at 125 1 last time before covering them
Yours were recheckd John i made sureShit .... .
Sent from my SCH-I510 using Tapatalk
Did you get the info from arps website???? i did all in sequence to 45 90 the 125 and backed them off in reverse order and then did the same process 2 more times and rechecked the next day to 125 again i hope i understood them and did this correctly????Wow, they've changed their install steps. Used to you cycled them 3 times at 125. Now they're saying not to.
I was always under the inpression it was the idea to prestreacth the studs so when under opperation and heat up and cool down they would hold solidYou did them correctly. I always cycle them 3 times. The old instructions said to, obviously the new ones say just to torque once. To tell you the truth I haven't read the instructions that come in the box for a long time. I've memorized pretty much every torque spec on a duramax. Haha.
