If you go with a 4202 you will have one of the chargers we are using in our twin it....
money is a issue at this point i dont think twins are in the near future
That way you can be 1000rwhp all day long with great driveability and low drive pressure.
Not to step on toes but with a Cheetah and a 4202 you will not be at 1000hp maybe 850 if that. For a 1000hp you would need a GT4094R twined with GT4718R.
We need Bradyen in here. I tommy i to will be going a differnt route on turbos. I was thinking about getting a 42 and im still debating But if Jrad says it true that a chetta is a little bigger then a 42 or the same size and can flow as much air as the 42 then my turbo will be a chetta
nice wht charger did you go with on your truck ? must feel good to be driving it again
seemsa alot of guys are going with s4000 latley. so heres a question any one think i could daily drive a gt45
Go BIG or go home.......
There has already been a couple of 4202R's installed on LMM's. No messaging the firewall needed. Get the ball bearing/watercooled.
How much power do you want to make is the simple question. We can go bigger then a std 4202R if you want? There is no way a regular 45 or 47 will fit with out some serious mods to the truck (can you says body lift????).
Some of the S400's are the same size if not bigger than a GT45, although the ETT compressor on the S400's offer a wider, more 'driveable' map (but give up a little peak boost). If you're going to compare, guys really should give you more info than just 'S400'. There's about 9 million different ones to choose from.
So, yes. I think you could daily drive it. You'll need to use the rev range, but you're already a Tap-shift pro :joker:
