I have the fass 240, it was the biggest at the time? I didnt know they uped it to 260, mines modified to pump around 35-40psi at an idle, it still holds around 25 at wot.
Yea the 260 can go toward 50 psi max
Not sure what the max is on the one i have, but it will max out a 40lb gauge, we just adjusted down cause i thought that was a little too extreme. If you have pressure, i dont see where 50 would help you more than 10psi.
Does aeromotive have diesel rated pumps? They got to have some marine rated, that would be fine I'm sure, I'd call and check though
Rob you don't run fuel to your FICM correct?
I talked to Fass last week about the 260 and they said it is 4.5"W X 9"L X 14"T. They said it is the same size as a usps large flat rate shipping box. They told me to go get a box and see if it fits were I need it too. Hope this helps.
Brett
