anyone rebuilt their lift pump electric motor?
JHForman
Oct 7, 2011
82
Southern Indiana
I apparently have a bad motor according to airdog, when I go WOT the fuel pressure gauge shows 0 depending on how full my tank is my idle pressure is 6-12 6 below half tank 12 above. so after talking with josh at airdog today i am being told the electric motor is bad/going bad. so just curious if anyone here has rebuilt one.
BigDMax05
Peanut butter and ladies!
Feb 2, 2009
337
Indiana
For 200 bucks I think they will send you a whole pump/motor assembly
I think your about right on the money. Call them and they will send you whatever piece you need. Just FYI in case you guys didnt know the biggest AD you can get from a dealer is a 200. I found out that AD sell's a competition pump that you can't get from a dealer and it's rated at 250gph but it's a special order pump. I called down there and they made mine the same day I called them so I went on ahead and drive on down there and picked it up. Pretty sweet pump to. It doesn't include the lines or fittings so that part is up to you.
rcr450mx
Dec 7, 2010
55
Indiana
If you buy another pump motor from them you will also get the lifetime warranty on that motor. Should run you $219 from air dog for the motor.
DetailsUnlimited
1,264
Benton, Ar
I have this pump also. AD2-250GPH. Has been working great sofar!
slipclutchms
427
It's funny cause they tell you it's a "motor" your getting for the 200 some odd dollars but in reality you get the motor and pump assembly....essentially everything but the aluminum distribution block the motor/pump sit on
