Just put in 750' of it in my house after the removal of old ceramic tile (took longer to remove the tile and thinset than to lay the new floor). As others have said, use your miter saw for cuts to pieces, but also having a table saw is not a bad idea in the event that your walls aren't square (been there, done that). Take your time, and realize this is not a one day project. It will take some time and effort, but when the prep work is done correctly, the moisture is kept out, and you don't do anything in haste, you have a beautiful floor which will last the 10 years you want to get out of it. Last piece of advice is to wear some sort of glasses when cutting this stuff. The plastic on the back of the laminate panels really hurts when it hits the old eyeballs. We only have one set you know...
P.S. put the beer cooler at the end of the room where you plan on finishing...if you put it at the beginning, you might have something that ends up looking like an Andy Warhol painting...:alc:
