anyone else have a hard time getting there oil return line to not leak
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
title says it all i have tried now three ****ing times still leaks im ready to send this thing packing over this new gaskets silicone no cracks in the flange or pipe itself still leaks an gets everywere wtf gives has anyone else ever had this hard of a time getting that thing to seal i know i never have before my own truck:mad:
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I've had the feeds on aftermarket chargers leak but it never with a return. Flange may be bent, or gasket is bad. I'd pull it off put a new gasket on and retorque it properly after checking for warping or cracks
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
yes the BD gaskets is junk it was new an leaked so i put right stuff on it tightened it down let it sit for awhile then started it up and let it get warm drove it around the block parked and another puddle of oil shit is old i bout have the f***er off again :mad: going to try buying another new gasket from gm an it wasnt warped or anything i checked everything an figured some silicone would cure it but nope. also think i have a smakll oil leak from my upper pan now to or maybe its just all the damn oil from the reurn line getting everywere
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
yes, the not so nice PPE sends with their install kit is leaking where they welded the extension piece in.
ive had that same problem. seems like they use dissimilar metals. had to have my 4088 tube brazed to make it stop leaking.
wdino73
735
55
Versailles, Ky
I made mine out of some sheet gasket material from advanced, then I took some rtv an put a little bit on each side of the gasket rubbed it in with my finger to make sure the entire surface is covered, careful not to glob it on, put it in an torqued it down, Good Luck just trying to help. I feel your pain though.:mad:
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
hey hondarider want to trade trucks yours just looks sweeter then mine :D an maybe ill run get some matriel an make my own gasket to its the stock return tube an it didnt leak before i never bent it when putting it in or pulling it? im sure its the gasket causing me hell:mad:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Yes since you have a better pistons than me and some bigger sticks :D
Not now, my hood is straight up, crap is thrown in my bed, and half my turbo setup is out of the truck.
I got 2 sets of the upper an lower drain gaskets from GM and they wer eliek 2.50 a piece just in case.
custom8726
2,784
Upstate N.Y
Just put the same set-up on mine and used the BD supplied gasket with NO Leaks. It seems to me something must be warped or mis-aligned on yours causing it to leak especially if you used RIGHT STUFF aswell as the gasket:confused: BTW it says on the RIGHT STUFF bottle no set up time is necessary before use;)
ripmf666
15,123
14
47
Wentzville Mo
Not sure what brought up the PPE drain pipe but its not in his kit.
In the BD kit did you install the
Oil Outlet Block and use 3 gaskets
install data attached
  • 1046200_-_Duramax_Supermax_Turbo.pdf
custom8726
2,784
Upstate N.Y
I did not realize the oil drain was different from the LB7 to LLY kit:confused: disregard my post on the extension and hose clamps above:eek:
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
i had that problem when i put on my 4094, leaked like a bastard retorqued still leaked.. made my own gasket and slightly overtorqued... solved the problem...
if you suspect the drain is leaking remove it and gently go over it with a butane torch and look for hairline cracks. braze or replace if necessary.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
well i made my own gasket and yes its got three gaskets and a 3 in block the upper part with the block isnt leaking just were it dumps the oil but..... made my own gasket right stuffed under and on top of the gasket ;) and i did check it for cracks none there think that gasket was just junk and im leaving to sit over night to all set up an dry out and ill re tourqe the nuts before i start it up and take it for a spin
custom8726
2,784
Upstate N.Y
its all good just trying to help:hug: ya lots differneces everywere and how are you liking your bd turbo how much boost you pulling?
Right around 38 or so, but I would like to see it in the 42 range;) still tinkering:) The only reason I choose this turbo was with the intentions of twinning it in the very near future when $$ allows. My opinion so far is, better spool up, slightly lower EGT's while towing/idling,, but still max's out my EGT gauge in the 1/4, and a small SOTP power increase IMO.. Over all I like it, but I would have gone alot bigger if I was going to stay with a single.
custom8726
2,784
Upstate N.Y
i want to twin to thats the same reason i bought it i also get 37-39 want to see 42 also it spikes around 42-43
I thought mine was making mid 40's from looking at my gauge but when I log it it only shows 38 as max:confused: I still have a bit of ajustment on the wastegate to toy with though. How do you like the charger so far?
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
its got good response slightly cooler in racing and towning still hit 1600 i think i dunno it gets going faster cant sit an watch the guage :thumb: need to put more fuel down low again my gauge shows the spike around 42-43 an holds 38 logs show 38-42 lbs i dunno its a good turbo cleans the 45% overs with a 2200 pw right up what pw you running with your 40%'s
